Monitor bandwidth of AP 225
Is there a way to monitor the bandwith utilization of several ap's that support a large conference room? The APs are the 225 model.
Re: Monitor bandwidth of AP 225
Do you have AirWave?
Tim Cappalli | Aruba Security
Yes
You can scope the RF Health report down to those APs if they're in their own
folder or AP group.
