Monitor bandwidth on RAP wired port?
Is there any way to monitor bandwidth usage on a wired port of a RAP device? We have a remote office with about 8 users connected via cable modem and a RAP3. I need a little insight on how much bandwidth is being used on port 2 of the RAP. Our side has a 7210 running OS 6.4.2.5.
ACMP - Feb 2014
Trusted Contributor I
Re: Monitor bandwidth on RAP wired port?
Airwave can pull these stats if you're monitoring the RAPs controller.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
