Monitoring total airgroup servers and users via SNMP
It there an SNMP variable for the total number of airgroup servers and users on a controller?  We are begining to roll out airgroups and would like a way to monitor how many servers and users there are on a given controller.
Re: Monitoring total airgroup servers and users via SNMP
Srbradley,
Unfortunately, there is none.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Like cjoseph mentioned this is not supported yet but feel free to do a RFE (Feature Request):
https://arubanetworkskb.secure.force.com/prm/ideas/ideaList.apexp
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thanks for the quick response.  One more question.  What happens when the tables get full?  Does the next entry not get installed or does it replace an old entry?
No new entries are added.
Tim Cappalli | Aruba Security
Moderator
hi srbradley
if you're not adverse to using a script/tool to do it, you can use something like AirRecorder which is an Aruba provided java based (runs anywhere) CLI SSH scripting tool to periodically run the relevant CLI commands - or roll your own.
Alternatively you can interogate the webUI interface, but that is a bit more involved and requlres you to use something like cURL.
In both cases the output still needs to be parsed and processed into something useful like CSV, but it can be done.
regards
-jeff
