Occasional Contributor I
Mount AP-105 to i-beam?
Is this possible!? Is there a kit for it?
Aruba
Re: Mount AP-105 to i-beam?
Yes, it's possible, but there's no special kit for it.
Attaching a picture of how this was solved at another customer, using the AP-105-MNT kit and standard beam clamps.
/Onno Harms, Aruba
/Onno
How do I view attachment?
Aruba
[ Edited ]
Good question. For some reason the image failed to attach. Inserting it here directly:
/Onno
