Mount IAP-228 to a electrical box
I have a warehouse that will be running dedicated conduit across the ceiling for each AP drop locations. I was wondering if anybody has had any luck mounting a IAP-228 to an electrical outlex box?
They'll put in any specifications I need but we cannot have any exposed wiring. I was thinking of running conduit to a an outlet box, but not sure if a mounting kits for a 228 fit with a double or single gang box.
Thanks for the help!
