Mounting kits info for AP324/AP325 and AP-ANT-48
I realised that the AP-220-MNT-W2W kit for AP324/325 is EOS as per "http://www.arubanetworks.com/assets/support/EOS_mountkits_160731-1.pdf". The replacement kit is AP-220-MNT-W3. Does anyone have the mounting kit installation guide and drill template?
Regarding the AP-ANT-MNT-4 mounting kit for AP-ANT-48, can I also have the installation guide and its dimensions?
Aruba
Re: Mounting kits info for AP324/AP325 and AP-ANT-48
Some relevant docs are attached. Note that these are also available on the Aruba Support website.
/Onno
