Contributor I
Mouting Kit Ap-220
Hello to all,
I need your help about one thing, I've got one AP 220 and I would like to know if this MNT KIT (attached) is compatible with this Ap, because I check out on the documentation and there is no mention about this mounting kit. Can you help me ?
Re: Mouting Kit Ap-220
If you have an AP-225, yes it is compatible. You just snap it on.
Tim Cappalli | Aruba Security
Contributor I
I have this Access Point AP-220-MNT-W1W . Is it compatible too ?
There is an ordering guide here:  http://www.arubanetworks.com/assets/og/OG_AP-220.pdf that says what is compatible.  Each AP-225 comes with a ceiling rail adapter.  Please see the installation guide here:  http://community.arubanetworks.com/aruba/attachments/aruba/expertday/173/1/AP-22X%20Installation%20Guide%20Rev%2002.pdf for details on that.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Yes.
Contributor I
Thank you for both of you :)
