Moving building in Visual RF
I am running Airwave 8.0.4. How does one move buildings from on campus to another in Visual RF? The old method I would use no longer works in this new version.
Moderator
Re: Moving building in Visual RF
This is another feature that missed the release deadline.  The workaround for now is to toggle back to Flash, make the change, then toggle back to HTML5.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Did they get this feature added in 8.0.7.1?
Moderator
It did not make it into 8.0.  We're looking at it for possibly 8.2.
Workaround is to use the flash version to move buildings.  Instead of doing so from VRF setup, you can cheat by just changing the URL:
https://<AMP NAME>.com/vrf ==> https://<AMP NAME>.com/site_list
This lets you use the flash version on the fly to make a few changes that will be reflected upon refresh in the HTML5 side.
Rob Gin
