Multi Vendor Integration
Hello Everyone ..
Recently i have been asked to setup new network based aruba controller ,
the costumer want to connect other vendor access point to the network via wifi uplink,
those other vendor APs can be configured in 2 ways ,
1.Bridge mode
2.Router mode (by preforeming nat ..)
Is there someone that already tried that with aruba equipment ?
Did you experience any difficulties establishing a similar configuration/topology?
thank you,
Re: Multi Vendor Integration
It would just have to be tested. Multiple types of client bridges have been used in multiple environments, but each one has to be tested based on the required configuration elements of each site. it should work fine, but it REALLY depends on what you are trying to accomplish.
Jerrod Howard
