Multicast Packets Getting Dropped from RAP Connected to SSID in Split Tunnel Mode
Environment:
Aruba Controller 620
Version: 6.3.1.20
RAP:  RAP5WN
Campus AP: AP105
RAP5---->Internet----> Controller 620 ----> AP105
SSID: Company-A-Branch
Split tunnel broadcasted to RAP5WN in remote branches
SSID: Company-A-Main
in Tunnel mode broacasted to AP105 Campus AP
For both SSID, they have the following same config except the mode above.
VLAN: 1
Dynamic Multicast Optimization (DMO) --> OFF
Drop Broadcast and Multicast -->OFF
Convert Broadcast ARP requests to unicast --> OFF
VLAN 1 Settings:
IGMP --> OFF
Enable BCMC Optimization --> OFF
Hi there,
I've a really strange problem with multicast packets being sent from Wifi users connected to Company-A-Branch but it is able to receive multicast packets being sent from Wifi users connected to Company-A-Main.  In a wireshark capture from a computer connected to Company-A-Branch, it sees no multicast packets from another device on Company-A-Branch on the same RAP5 locally.
However, if I change Company-A-Branch mode from Split-Tunnel to Tunnel, then everything works instantly.  Multicast packets sent locally can be received locally and across to devices in Company-A-Main.
I would like to understand whether this is by design that split tunnel drops multi-cast or there is some additional parameters that I'm missing?
David
Re: Multicast Packets Getting Dropped from RAP Connected to SSID in Split Tunnel Mode
It depends.  What is the firewall policy for users in the role at the RAP-5?  What kind of multicast traffic is it?
Hi Colin,
The session ACL under the RAP AP System points to allowall policy which is
IPv4 any any any permit Low
David
I mean the ACL in the user role assigned to the split tunnel SSID.
The mutlicast packets are some push to talk packets encrptyed
ACL as follows
split-tunnel
Priority  Source  Destination  Service    Action         TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6
1         user    any          udp 68     deny                                    Low                                                           4
2         any     any          svc-dhcp   permit                                  Low                                                           4
3         any     any          svc-dns    permit                                  Low                                                           4
4         any     any          IPSec-ESP  permit                                  Low                                                           4
5         any     any          svc-ike    permit                                  Low                                                           4
6         any     any          any        route src-nat                           Low                                                           4
allowall
1         any     any          any      permit                           Low                                                           4
Do the multicast packets correspond to the line here?
To find out what traffic is being sent in a split tunneled SSID, type:
show datapath session ap-name <name of ap> table <ip address of client>
to see what traffic is being sent by the client and how it is being handled when the PTT is active.  Please send the output of that so we can understand what is going on.  I honestly have never seen IPSEC sent to a multicat destination before...
Hi Colin
Sorry for the late reply.  Here is the output while on the split-tunnel SSD
  Source IP     Destination IP  Prot SPort DPort  Cntr Prio ToS Age Destination TAge Packets   Bytes      Flags
192.168.78.50   31.13.76.101    6    43568 443    0       0 0   6   local       1d8  0         0          SRC
192.168.78.50   216.58.221.106  6    37428 443    0       0 0   8   local       279  0         0          SRC
234.5.6.6       192.168.78.50   17   2010  45472  0       0 0   0   local       b    0         0          FY
192.168.78.50   192.168.78.254  6    48193 80     0       0 0   0   dev18       12   0         0          FHCI
192.168.78.50   173.194.203.188 6    40062 5228   0       0 0   8   local       26a  0         0          SRC
192.168.78.254  192.168.78.50   6    80    42827  0       0 0   0   dev18       12   0         0          FH
192.168.78.50   210.5.174.66    6    38772 5222   0       0 0   8   local       282  0         0          SRC
192.168.78.50   192.168.78.254  6    42827 80     0       0 0   0   dev18       12   0         0          HCI
192.168.78.50   75.101.136.208  6    48101 443    0       0 0   3   local       e1   0         0          SRC
192.168.78.50   234.5.6.6       17   45472 2010   0       0 0   0   local       b    0         0          FRC
192.168.78.50   64.233.188.188  6    40961 5228   0       0 0   4   local       283  0         0          SRC
192.168.78.50   31.13.76.66     6    38065 443    0       0 0   6   local       1d9  0         0          SRC
192.168.78.50   31.13.76.101    6    42130 443    0       0 0   8   local       284  0         0          SRC
192.168.78.50   218.189.210.3   17   45475 123    0       0 0   1   local       33   0         0          FSRC
192.168.78.254  192.168.78.50   6    80    48193  0       0 0   0   dev18       13   0         0          FH
While on the the tunnel mode SSID
192.168.78.50   234.5.6.6       17   40615 2010   0       0 0   0   dev12       11   0         0          FC
I am not sure about the policy
As this seems to have came default when we first installed the Aruba Controller.   And we weren't sure whether it is needed.  What we wanted was split tunnel in that policy.  So I assume all we need moving forward is?
ip access-list session split-tunnel
