Occasional Contributor I
Multizoning with clustering
Why does it give me an error while enabling multizoning when I have a MC cluster in place? As soon as I remove the MC's out of the cluster the command works.
Thanks!!
Re: Multizoning with clustering
Do you have HA enabled?  That is the error message I see.
Yes I have HA cluster enabled. Isn't this topology with a HA cluster in primary zone supported?
Do you have a diagram of what you're trying to accomplish between the primary zone controllers and the data zone environment.
@manish.modi
Charlie Clemmer
Aruba Customer Engineering
