NAT / ACL Problem
  • 1.  NAT / ACL Problem
    Posted Dec 12, 2014 05:36 AM
    i have a active/passiv 2 controller vrrp installation with 2 vlans. 1= internal 2. = mobile
    controller is not default gatway of the vlans.
    now i need to configure, that a modile device can access a server. It is possible?
    I don not get the nat to work. the installation is for mobile devices so i cant get any routes into the client devices.
  • 2.  RE: NAT / ACL Problem
    Posted Dec 12, 2014 06:02 AM
    Can you bring some more clarity on this,
    1.If the Controller VRRP IP is not he GW for the clients then how your controller is up linked ?
    2.what do you mean by mobile devices are they wireless clients ?
    3. You want to access the servers so where are these servers ?
    Please clarify so that I can help you on this.
  • 3.  RE: NAT / ACL Problem
    Posted Dec 12, 2014 06:22 AM
    1. the controller got his default gateway in vlan 1 (which is internal lan). vlan 2 is a single internet access with own router
    2. the clients are wireless devices, but iphones etc. where i can't add any route etc. i do the
    testing with a laptop, whe i add a route to use the controller as gateway it works
    3. the clients in vlan2 should access 1 server in vlan 1
    vlan1 got now route to vlan 2, therefore i need to nat at the wireless controller. i think i need some interception like the captiv portal does its redirect
  • 4.  RE: NAT / ACL Problem
    Posted Dec 12, 2014 07:05 AM
    with a "route+srcnat" icmp is working, but i get no telnet answer?!
  • 5.  RE: NAT / ACL Problem
    Posted Dec 12, 2014 07:20 AM
    HI,
    Is the Router, providing internet manageable ? if yes configure inter VLAN routing so that it can come back to the controller and then reach the internal VLAN ( VLAN 1). here assuming that the controller having connectivity to the internal servers :)
    Ensure that, controller is having VLAN 1 and VLAN 2 interfaces configured.
    If the Router is not manageable we have to look at other options :)
    Make sense ??
  • 6.  RE: NAT / ACL Problem
    Posted Dec 12, 2014 07:27 AM
    if i configure a route on the internet router in vlan2 i will have an routing triangle.
    can you ecplain me, why action "route" in  the acl i working for ICMP but not for telnet?
  • 7.  RE: NAT / ACL Problem
    Posted Dec 12, 2014 07:48 AM
    HI,
    I'm not sure, can you check the user role and the policy mapped is allowing the desired traffic ??
  • 8.  RE: NAT / ACL Problem
    Posted Dec 12, 2014 08:02 AM
    the user role ist matching and the acl is
    any sorce - destination host x.y.z - any service - action route
    interface has source nat activated
    sh datapath session shows the same for icmp and telnet but the telnet session is not working
  • 9.  RE: NAT / ACL Problem
    Posted Dec 12, 2014 08:22 AM
    Ok, let me replicate this and bring some solution , give me some time :)
  • 10.  RE: NAT / ACL Problem
    Posted Dec 12, 2014 08:34 AM
    thats my config change today
    interface vlan 1
            ip address 192.168.1.241 255.255.255.0
    interface vlan 2
            ip address 192.168.2.2 255.255.255.0
            ip nat inside
    ip access-list session ROUTE
      user host 192.168.1.100 any  route log
    user-role Mobile
     access-list session allowall
  • 11.  RE: NAT / ACL Problem
    Posted Dec 12, 2014 08:52 AM
    I just had a discussion with my friend, I got your point.
    Please try with ESI redirec , should work :)
    for help , go through this link.
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/How-to-NAT-and-redirect-of-specific-traffic-using-ACL-on-Aruba-controller-if-Aruba-controller-is-not-the-gateway-for-the-client
    Hope your issue will get resolved.
    please feel free to come back for any further help on this.
  • 12.  RE: NAT / ACL Problem
    Posted Dec 12, 2014 09:57 AM
    i tried esi-redirect (with forward and both directions)
    i also get output
    192.168.1.100     192.168.2.169     6    23        54526  0/0     0 24  1   local       13   0         0          Y
    192.168.2.169     192.168.1.100     6    54526  23        0/0     0 24  1   local       13   0         0          YTC
    but still no connection. I don't get it. Will update the controller to 6.4 on monday
  • 13.  RE: NAT / ACL Problem
    Posted Dec 15, 2014 04:12 AM
    Hi Friend,
    You have a good solution in 6.4.2.2  it supports Policy based Routing :)
    All the best.
    Please feel free if you need any help on this.
  • 14.  RE: NAT / ACL Problem
    Posted Sep 02, 2015 10:37 AM
    i have 6.4.2.8 running and a working esi rule for redirecting trafic from vlan 1 to vlan 2 without beeing default gateway
    vlan1 = 192.168.110.0
    vlan2 = 192.168.0.0
    for vlan 1 i have a esi rule like:
     source: user -> any service -> destination: 192.168.0.100 -> action: redirect esi-group 192.168.0.100 (direction both)
    thats working for me. BUT now i need to nat  traffic for 10.10.10.10 to the 192.168.0.100 Server
