Occasional Contributor I
NEW TO ARUBA-- NEED HELP WITH CONTROLLER 6000 SETUP
Good Evening All
Need some help with a donated Aruba Controller 6000 WS-5004 with OS locked at current ArubaOS 5.0.4.17. Controller has 128 AP licenses and 2 license for firewall and Policy Apps none expired...lucky Me!!
Since I dont have any support contracts with Aruba yet..its hard to get any support from Aruba from start to finish. I am supporting a small boarding School and we need to replace the current Unfi Ap's ASAP!!! They are not not holding up well in the classroom overload.
I need to setup this with the following:
Vlan 1 Native - DHCP
vlan 8  Student Network - DHCP
van 30  Faculty Network - DHCP
vlan 40 Future Use
Port 24-25 Trunk Port
Port 23 INTERNET UPLINK PORT
Right there is a 7 cisco POE switches feeding current ap's around campus soon to be aruba
I have two routers for bother networks but can use port 23 as an uplink for a router if need be.
Controller will be connected to the current cisco poe switched via Trunk to controller Aruba Ap's
I will be so greatful for any help that is given. I really could use a step by step from start to finish if possible
Regards
Re: NEW TO ARUBA-- NEED HELP WITH CONTROLLER 6000 SETUP
Take a look at this video:
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/COTD-Initial-Setup-Video-of-an-Aruba-Controller/td-p/11784
One thing to consider. You only have 2 PEFNG licenses which means your APs will be capped at 2. You'll want to either acquire more PEFNG licenses or remove the PEFNG license altogether.
Tim Cappalli | Aruba Security
tbradley wrote:
Good Evening All
vlan 40 Future Use
Regards
tbradley,
The cli configuration is very Cisco-Like.  Do this:
config t
vlan 1
vlan 8
vlan 30
vlan 40
interface fastethernet 24 (or whatever it is)
switchport mode trunk
switchport trunk native vlan 1 (or whatever you want)
switchport trunk allowed vlan 1,8,30,40, etc
exit
The 5.x user guide in the folder here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/3795/Default.aspx will tell you how to create WLANs.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
