MVP
NMSP / CMX integration with Aruba controller - is it possiable?
Hi Guys,
I have a client that asking if there is any  NMSP  / CMX integration with Aruba controller and if it possible?
( i know it's CISCO solution but my client asked me to know if anyone did such of integration in the past)
Anyone here did someting similer in the past? or deployed such kind of solution?
MVP
Re: NMSP / CMX integration with Aruba controller - is it possiable?
There's no direct integration no, those are Cisco proprietary protocols specific to their products only. What are they trying to do?
Jerrod Howard
Sr. Techical Marketing Engineer
MVP
Thanks for the fast resposne.
The client asked if he can use Aruba infrastruce to supply NMSP > CMX services... (To show cisco abilites :-L )
( i gave him the same answer as u wrote...but i decided to check..)
MVP
Yea, the answer is a nope...
Jerrod Howard
