Need Help client cannot connect to AP with alert Message to Controller Timed Out
Hi all,
suddenly we are facing mysterious problem. Client cannot connect to AP. And keep restarting the process authenticating obtaining IP address. like very quick connect and disconnect mechanism. Without even giving a chance the user to obtain dhcp IP.
Here is what i got from command
show ap client trail-info
Client Trail Info
MAC                BSSID              ESSID               AP-name  VLAN  Deauth        Reason                               Alert
14:30:c6:a0:d6:14  24:de:c6:0d:07:c5  DOMIKADO Free WiFi  AP-TEST  312   Station        Up Message to Controller Timed Out  Station Up Message to Controller Timed Out
Deauth Reason
Reason                                      Timestamp
Station Up Message to Controller Timed Out  Dec 19 17:27:37
Station Up Message to Controller Timed Out  Dec 19 17:27:35
Station Up Message to Controller Timed Out  Dec 19 17:27:34
Station Up Message to Controller Timed Out  Dec 19 17:27:33
Station Up Message to Controller Timed Out  Dec 19 17:27:32
Station Up Message to Controller Timed Out  Dec 19 17:27:31
Station Up Message to Controller Timed Out  Dec 19 17:27:30
Station Up Message to Controller Timed Out  Dec 19 17:27:29
Station Up Message to Controller Timed Out  Dec 19 17:27:27
Station Up Message to Controller Timed Out  Dec 19 17:27:26
Num Deauths:10
Alerts
Reason                                      Timestamp
Num Alerts:10
Mobility Trail
BSSID              ESSID               AP-name  Timestamp
24:de:c6:0d:07:c5  DOMIKADO Free WiFi  AP-TEST  Dec 19 17:27:37
24:de:c6:0d:07:c5  DOMIKADO Free WiFi  AP-TEST  Dec 19 17:27:36
24:de:c6:0d:07:c5  DOMIKADO Free WiFi  AP-TEST  Dec 19 17:27:35
24:de:c6:0d:07:c5  DOMIKADO Free WiFi  AP-TEST  Dec 19 17:27:34
24:de:c6:0d:07:c5  DOMIKADO Free WiFi  AP-TEST  Dec 19 17:27:33
24:de:c6:0d:07:c5  DOMIKADO Free WiFi  AP-TEST  Dec 19 17:27:32
Num Mobility Trails:10
(Backup-BIT-Aruba-Cyber) #show ap client trail-info 14:30:c6:a0:d6:14
Client Trail Info
14:30:c6:a0:d6:14  24:de:c6:0d:07:c2  doku free wifi  AP-TEST  312   Station Up Message to Controller Timed Out  Station Up Message to Controller Timed Out
Deauth Reason
Reason                                      Timestamp
Station Up Message to Controller Timed Out  Dec 19 17:29:59
Station Up Message to Controller Timed Out  Dec 19 17:29:58
Station Up Message to Controller Timed Out  Dec 19 17:29:55
Station Up Message to Controller Timed Out  Dec 19 17:29:54
Station Up Message to Controller Timed Out  Dec 19 17:29:53
Station Up Message to Controller Timed Out  Dec 19 17:29:52
Station Up Message to Controller Timed Out  Dec 19 17:29:51
Station Up Message to Controller Timed Out  Dec 19 17:29:50
Station Up Message to Controller Timed Out  Dec 19 17:29:48
Station Up Message to Controller Timed Out  Dec 19 17:29:47
Num Deauths:10
Alerts
Reason                                      Timestamp
Num Alerts:10
Mobility Trail
24:de:c6:0d:07:c2  doku free wifi  AP-TEST  Dec 19 17:29:59
24:de:c6:0d:07:c2  doku free wifi  AP-TEST  Dec 19 17:29:58
24:de:c6:0d:07:c3  DOMI_TEST       AP-TEST  Dec 19 17:29:55
24:de:c6:0d:07:c3  DOMI_TEST       AP-TEST  Dec 19 17:29:54
24:de:c6:0d:07:c3  DOMI_TEST       AP-TEST  Dec 19 17:29:53
Re: Need Help client cannot connect to AP with alert Message to Controller Timed Out
We need much more information like:
- What client is this?
- What access point type is this?
- What type of encryption is being used?
- What version of ArubaOS?
- Is this the only client that is having this problem?  For how long?
EDIT:  If this is 6.4.1.0, please upgrade to 6.4.2.1 or later to fix this.
any WiFi client, connected to AP
AP 135 with RAP configuration
anything, from WPA and Open SSID With Captive Portal
ame:Aruba Operating System Software.
Model:Aruba3600
Version:6.4.2.0
Compiled:2014-08-04 at 18:58:33 PDT (build 45199) by p4build
happening more than one time
what actually happen when alert Message to Controller Timed Out is happening.
lend3,
You need to upgrade to 6.4.2.1 and above.  From the 6.4.2.1 release notes:
