Need Help with bandwidth throttle - ASAP
Hello All,
The issue I am having is with my SSID Bandwidth throttle. We currently have 3 SSID's in place - one is for employees, the second one is for Guests, and the third one is for Phones/Tablets.  Well, the problem is that the Guests and Phone/Tablet SSID's was configured with low throughput.
I thought the setting was under Configuration / Security (Access Control) / Select the User Role (guest) and edit / Bandwidth Contract - but according to the gui, it's not enforced.   Am i looking in the right place?  Where can i find the setting, whether it's through the gui or the CLI.
Our Controller is a 3400 running OS 6.1.2.5.
Thank you in advance.
Re: Need Help with bandwidth throttle - ASAP
Where do you see it say it's not enforced?  I've done the same as you outlined for several networks I have configured and it works fine.
-Mike
all user and group roles show not enforced.  however, if i log into either of those two SSID's i notice a big bandwidth difference when i navigate the web or go to speedtest.net.
Where does it say "not enforced"?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
