Need Usb console driver for IAP-345
Dear All,
The IAP-345 is using Micro-usb for console function rather than the RJ45 one.
When I try to use Micro-usb connect to that lovely and pissed me off usb port, Windows just notices me that the USB port is not identified.
Well, seems I need driver for it.
And the Aruba website provided driver is really good but not works for it.
Anyone can help? Please!
Re: Need Usb console driver for IAP-345
It is a special cable:  AP-CBL-SERU
https://support.arubanetworks.com/ToolsResources/tabid/76/DMXModule/514/Default.aspx?EntryId=27916
Please see the installation guide here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=30834
