Need an opinion
Hi guys I am new to all of this. The nature of my business subscription based access to wifi hotspots.
And I am considering  expanding my network but for hardware I am thinking about Huawei AP6510DN-AGN and AP6610DN-AGN but I am not sure will they work with ClearPass? Has any one used Huawei access point hardware with ClearPass and how was your experience?
Re: Need an opinion
If they use standards-based RADIUS, they will work. ClearPass works with
nearly everything that follows IETF and IEEE standards.
Tim Cappalli | Aruba Security
Re: Need an opinion
IEEE 802.11a/b/g/n so I guess it should work.
Re: Need an opinion
I meant more along the lines of authentication standards.
Re: Need an opinion
what about switches? Does clearpass work with Huawei switches and also access controllers?
Trusted Contributor I
Re: Need an opinion
the same applies as with access points, if the switches use RADIUS for authentication of users / ports then they can work with ClearPass. for the rest it usually depends on what the switches supports, ClearPass can do pretty much everything.
