Need assistance with 620 and Authentication Times Extended
Just started managing a new customer's site, and they have a 620 running the wireless.
Customer has requested that 2 of the 3 profiles/accounts used to access (One is Corp, Other is Guest and then Tenant) allow the end user to keep the ability to leave the network and return to the site without having to sign back in or authenitcate.
Being new to the Aruba, any help would be greatly appreciated.
Re: Need assistance with 620 and Authentication Times Extended
What type of authentication are they using?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Appears to be AAA, with a 802.1X.
802.1x meaning WPA/2-PSK?   How do they connect?  The supplicant on the device, after waking up, should try to reconnect them, typically.
Should be just the WPA/s-PSK. Kind of stunmbling around the Aruba, as I am more fluent with Cisco.
If the users are using a single preshared key to connect, when they come back to their devices, they should attempt to connect back to the network by themselves.
What exactly is happening?
Yeah, the customer has a preshared key used by guests.
When the device sits idle and/or leaves the network, they are prompted to re-enter the key.
Customer wants the timeout/return to be around 7 days.
What devices are those? It should just reconnect. The controller cannot force a prompt for a PSK. It is the supplicant on the device that would do that.
Thinkind it is Apple related.
Being told that it is all devices.
Laptops once they go to sleep are prompting the visiting users to re-enter the pre-shared key.
