Occasional Contributor I
Need help new to Aruba and have no details for the system !!
Hi Guys and girls.
After a bit of help just taken on a new client as the old IT company has gone awol and its taken a couple of days just to get to where we are now. I have access to the servers now the NAS, CCTV etc and now the last piece of the jigsaw in is the AP's. Got a sonic wall in place to which i have managed to access and can see thats dishing out DHCP on two ranges how ever doing an IP scan on both ranges i cant see any AP's or the controller. The controller is a ARCN0104 which i believe is a cloud based controller. So if the client has no details the old IT compnay are no more and uncontactable how would i gain access to it ?
Any help is greatly appriciated :)
Many Thanks
Rob
Re: Need help new to Aruba and have no details for the system !!
Do you have the ip address of the controller?
Hi there, nope can see it on either range using angry ip scanner can see nothing !!
i can see two devices labelled as
Hostname:    ACA81112.ipt.aol.com
would that be it ?
Contributor I
Hopefully you have a Cisco console cable and com port on your PC (+fysical access to the controller)?
Put it in the console port on the controller and use following credentials user: password
password: forgetme!
Go into enable mode by typing "enable"
Enable password = enable
Type "configure terminal"
Reset the admin password
"mgmt-user admin root"
> choose a new password
Log out via exit
Now log in via admin/ new password
enable
show ip interface brief
Now you should have the ip adress and should be able to access the GUI with your credentials.
Awsome :) Ill try that tomorrow dont have my serial cable on me so will let you know tomorow how it goes thank you so much
Do i need to set the baud rate on the com port or any specific setting ?
Contributor I
9600
(use standard putty settings)
Hi Guys,
Just to let you know all is working now and we have reset the password thanks for you help much appriciated and i am sure ill be asking more questions.
Thanks again
Rob
