Need help to console in and reset 2400 Controller
I found an old 2400 Controller buried in a box in a data center.  Can someone tell me how to console in and reset everything so I can access the GUI and possibly play around with this to learn a thing or two?  If there is a thread with this question answered, please let me know.  Novice level experience with wireless.  Thank you in advance.
Re: Need help to console in and reset 2400 Controller
If you have a serial console cable, you probably will need to start with a password recovery: http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Password-Recovery/td-p/13220
If you have access again via de console, run a 'show license verbose' and store the output of the licenses. Then you can do a 'write erase', to clear the configuration and get started from scratch, or a 'write erase all' that fully factory defaults the box and you will need to add licenses again.
In addition to Herman's response, anticipate that this controller will have some pretty old code, and is not likely to support the current model APs.
Charlie Clemmer
Aruba Customer Engineering
This worked perfectly.  Thank you.
