Need help to design Solution for Hospitality Wireless
Dear Leads,
One of our Customer wants a Wireless Solution for his chain of coffee shops.
What the client wants is, when ever a guest enters his coffee shop he should be able to connect the guest wireless without any authentication, but the access to that customer should be just for one hour after that the access should be revoked.
Scenario 1 -
When the guest connects to that SSID, he should be redirected to the webpage kind of socail media links of the client coffee shop. Where he should get an option to enter his details like mobile number and name once he submited his details he should get the Guest wireless pasword on his mobile via sms.
Scenario 2 -
When the guest connects to that SSID, he should be redirected to the webpage kind of social media links of the client coffee shop and there should be a option for connect to guest wireless
Request you all to please help to design the solution.
Awnish.
Re: Need help to design Solution for Hospitality Wireless
This could be a pretty simple setup using ClearPass Guest and Instant. Are
you working with an Aruba Partner?
Tim Cappalli | Aruba Security
Thanks Tim for your reply, we are a HP Partner, can you please brief more on ClearPass Guest and Instant.
Awnish.
