Need help to enable and configure WebCC
I am running Aruba OS 6.5.1.4, I have the following licenses
Access Points: 15
Policy Enforcement Firewall for VPN users
Next Generation Policy Enforcement Firewall Module: 15
RF Protect: 15
and i am trying to get the Web Content Control working.
I have checked the solution exchange but the command firewall web-cc doesn't work.
And while i have added to the Global-sacl the web classification, it still allows to me the sites. I have also enabled ip name-server.
Has this feature been removed? or is it implementation now different?
Andy
Re: Need help to enable and configure WebCC
https://community.arubanetworks.com/t5/tkb/articleprintpage/tkb-id/ControllerBasedWLANs/article-id/2034
Enable the controller DNS lookup and define the DNS servers
https://community.arubanetworks.com/t5/Wired-Networks/How-to-configure-name-server-on-switch-to-use/ta-p/177844
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thanks Victor,
currently get no options for web-cc
(CTR01) #show web-cc
% Invalid input detected at '^' marker.
(CTR01) #show web-?
web-proxy               Web proxy server information
web-server              Display web server configuration and statistics
So config looks like, I must be missing something.
ip domain lookup
ip name-server 192.168.1.1
ip name-server 8.8.8.8
I tried the ping
(CTR01) #ping www.yahoo.com
Press 'q' to abort.
Sending 5, 92-byte ICMP Echos to 87.248.98.8, timeout is 2 seconds:
Aruba
Do you have any WebCC licenses?  I don't see them listed.
There is a subscription license associated with WebCC:
http://www.arubanetworks.com/assets/ds/DS_WebCC.pdf
AMFX | ACCX | ACDX | ACMX
Thanks, didnt realise it required another licence, one is on the way.
