Occasional Contributor I
Need help with IAP 105 and IAP275
Using IAP105 and IAP275 in Instant. Both have firmware 6.4 current. I see both units in Access Points with Mac Address. The IAP275 has a * at the end of the address. Have no wifi output on the IAP275. I'm betting I just need to enable something, but haven't figured it out.  Thanks
Re: Need help with IAP 105 and IAP275
the * means its acting as the VC (virtual controller)
what do you mean you have no WiFi output?
can you share the output of 'show AP bss-table'?
is your iap-275 configured as an air monitor?
what full firmware file are you using?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
No signal strength when I move from the 105 towards the 275.
Not sure how to   'show AP bss-table'
Have not configured as Air Monitor. Just matched the default of the 105
6.4.2.6-4.1.1.11_52666
Red Light on LED. Changed PoE to make sure that wasn't the problem
From the Virtual controller, you should be able to see the power and channel of both access points...
it shows IP address, Monitor ( even though set to access and rebooted twice), Mesh N/A, 275 type and ------- for everything else.
