Need some clarification on aruba 6000 chassis
Hi All,
I have Aruba 6000 chassis with a M3 card installed currently iit supports 512 AP.  I want to deploy more AP (around 2000 AP) in my network. If I install another three M3 card on the same chasis, will it support 2048 AP's?   Do we have any limitation?
Thank you.
Re: Need some clarification on aruba 6000 chassis
Yes , you can have 4 M3s (same chassis) each with 512 APs but need to pay attention to the controller performance when AP capacity is at 100% and a lot of clients .
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Super Contributor I
You can do that with a fullfledge 4 X M3K in a single chassis. Master controller performance is something you may want to take note. Why not get a 7240 and together with your existing M3K, price maybe cheaper and better performance.
Normal Guy
