Need to reset 3200MX to factory default
Sirs, I am setting a 3200 Controller up for it was partially and incorrectly setup. I am unable to access the WEB GUI and need to reset this to factory default to completely restart the process. Any assistance with this procedure will be appreciated. Thank you.
Re: Need to reset 3200MX to factory default
Did you try to access via the console?
"write erase" will do it.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thank you.
