New Aruba Solution Exchange for RF Optimization based on building types
See below for the link and summary.
This RF optimization solution will modify a selected "existing" AP-group as well as "clone" selected "existing" Virtual AP profile[s] and "existing" SSID profile[s] to create new optimized equivalent profile[s] with a user selected "suffix" appended to the existing profile[s] name . Using "existing" Virtual and SSID profile[s] are necessary to enable a successful "clone" of the existing parameters in each profile[s] that are to be maintained and not required to be optimized [i.e.VLAN,encryption mode, ESSID]. New radio, arm and ht-radio profiles will also be created based on the selected deployment model. All of the newly optimized profiles will then be applied to the AP-group. The original "cloned" profiles will be removed from the AP-group.
https://ase.arubanetworks.com/solutions/id/75
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Re: New Aruba Solution Exchange for RF Optimization based on building types
Very cool
Thank you
Victor Fabian
Lead Mobility Architect @WEI
