Contributor I
New RAP-5 won't find controller on same switch
I've confirmed connectivity on my laptop of the cable going to port 0.  RAP-5 comes up, and it has an IP address.  I give it the IP address of the controller (when connected to same cable I can DHCP and then connect to the controller IP from laptop),
The Remote Access Point Provisioning Page initially shows the RAP has an IP, Link OK, and Gig connectivity.  I enter the IP of the controller, and then the says receiving IP information, then moves to "Continuing".  At that point the RAP displays no IP and stops functioning (except to open up additional browser tabs).
Controller only has 1 AP on it.  I never see this AP show up in the list.
The PDF says some debugging is possible.  Can anyone point me in the right direction?
Re: New RAP-5 won't find controller on same switch
You can do the following :
show datapath session | include 4500 , this is the port it uses on the controller
show crypto ipsec sa , make sure Phase 1/2 is working
for debudding purposes you can use this :
logging debugging security process crypto
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Make sure that you have the mac of the RAP on the whitelist
Thank you
Victor Fabian
Contributor I
Perhaps I was being dense.  I assumed the thing would come up as an "un-provisioned AP" and then I could copy/paste the Whitelist info.  Lemme add it manually.
What AOS do you have installed ?
Because you might have to upgrade the backup flash
See this post
http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-apflash-backup-partition-or-how-do-I-upgrade-my-RAP5/td-p/5829
Thank you
Victor Fabian
Contributor I
6.1.3.9
Is that a brand new RAP5 ?
You may need to do the flash backup upgrade to work on AOS 6.x.x.x
Thank you
Victor Fabian
Contributor I
I Googled that and isn't that a controller function?  How can I flash-backup an AP that won't connect to the controller?  Is there a way that I am missing to console directly to this AP?
In order for you do this your controller needs to be on a AOS 5.x.x.x so this way the RAP can connect to the controller and then upgrade the backup flash.
Thank you
Victor Fabian
Contributor I
Ok thanks
