MVP
Newly converted IAPs to Campus APs registers the controller as Air Monitor APs.
I have a setup wherein the country code is different from the country code defined under the regulatory domain of AP groups and it is working fine with my setup of over 200 + APs. So the requirement of having both as same appears not as an compulsion link
I have recently converted over 20+ Instant APs to Campus APs to register with the controller. The problem is they all are showing up as Air Monitors.
Below is the radio related configuration:
(WLC_001) #show country
Country:QA
Model:Aruba7240XM
Hardware:Unrestricted
(WLC_001) #show ap-group APC
AP group "APC"
Parameter Value
Virtual AP VAP1
Virtual AP VAP2-vap_prof
Virtual AP GUEST-vap_prof
802.11a radio profile default
802.11g radio profile default
Ethernet interface 0 port configuration default
Ethernet interface 1 port configuration default
Ethernet interface 2 port configuration shutdown
Ethernet interface 3 port configuration shutdown
Ethernet interface 4 port configuration shutdown
AP system profile default
VoIP Call Admission Control profile default
802.11a Traffic Management profile N/A
802.11g Traffic Management profile N/A
Regulatory Domain profile default
RF Optimization profile default
RF Event Thresholds profile default
IDS profile default
Mesh Radio profile default
Mesh Cluster profile N/A
Provisioning profile N/A
AP authorization profile N/A
(WLC_001) #show ap regulatory-domain-profile "default"
Regulatory Domain profile "default"
Parameter Value
Country Code US
Valid 802.11g channel 1
Valid 802.11g channel 6
Valid 802.11g channel 11
Valid 802.11a channel 36
Valid 802.11a channel 40
Valid 802.11a channel 44
Valid 802.11a channel 48
Valid 802.11a channel 149
Valid 802.11a channel 153
Valid 802.11a channel 157
Valid 802.11a channel 161
Valid 802.11a channel 165
Valid 802.11g 40MHz channel pair N/A
Valid 802.11a 40MHz channel pair N/A
Valid 802.11a 80MHz channel group N/A
Valid 802.11a 160MHz channel group N/A
(WLC_001) #show rf dot11a-radio-profile default
802.11a radio profile "default"
Parameter Value
Radio enable Enabled
Mode ap-mode
High throughput enable (radio) Enabled
Very high throughput enable (radio) Enabled
Channel N/A
Transmit EIRP 20 dBm
Non-Wi-Fi Interference Immunity 2
Spur Immunity 0
Enable CSA Disabled
CSA Count 4
Spectrum Monitoring Disabled
Smart Antenna Enabled
Spectrum Monitoring Profile default-a
Advertise 802.11d and 802.11h Capabilities Disabled
Spectrum Load Balancing Disabled
Spectrum Load Balancing Mode channel
Spectrum Load Balancing Update Interval (sec) 30 seconds
Spectrum Load Balancing Threshold (%) 20 percent
Spectrum Load Balancing Domain N/A
Beacon Period 100 msec
Beacon Regulate Disabled
Advertized regulatory max EIRP 0
ARM/WIDS Override OFF
Reduce Cell Size (Rx Sensitivity) 0 dB
Energy Detect Threshold Offset 0 dB
Management Frame Throttle interval 1 sec
Management Frame Throttle Limit 20
Maximum Distance 0 meters
RX Sensitivity Threshold 0 dB
RX Sensitivity Tuning Based Channel Reuse disable
Adaptive Radio Management (ARM) Profile default-a
High-throughput Radio Profile default-a
AM Scanning Profile default
(WLC_001) #show rf dot11g-radio-profile default
802.11g radio profile "default"
Parameter Value
Mode ap-mode
Very high throughput rates enable (256-QAM) Disabled
Channel N/A
Enable CSA Disabled
CSA Count 4
Spectrum Monitoring Profile default-g
Protection for 802.11b Clients Enabled
Adaptive Radio Management (ARM) Profile default-g
High-throughput Radio Profile default-g
(WLC_001) #show ap system-profile default
AP system profile "default"
Parameter Value
RF Band g
RF Band for AM mode scanning all
Native VLAN ID 1
Tunnel Heartbeat Interval 1
Session ACL ap-uplink-acl
Corporate DNS Domain N/A
SNMP sysContact N/A
LED operating mode (11n/11ac APs only) normal
LED override Disabled
Driver log level warnings
Console log level emergencies
SAP MTU 1200 bytes
RAP MTU 1200 bytes
LMS IP 192.168.0.12
Backup LMS IP 192.168.0.11
LMS IPv6 N/A
Backup LMS IPv6 N/A
LMS Preemption Enabled
LMS Hold-down Period 600 sec
LMS ping interval 20
Remote-AP DHCP Server VLAN N/A
Remote-AP DHCP Server Id 192.168.11.1
Remote-AP DHCP Default Router 192.168.11.1
Remote-AP DHCP DNS Server N/A
Remote-AP DHCP Pool Start 192.168.11.2
Remote-AP DHCP Pool End 192.168.11.254
Remote-AP DHCP Pool Netmask 255.255.255.0
Remote-AP DHCP Lease Time 0 days
Remote-AP uplink total bandwidth 0 kbps
Remote-AP bw reservation 1 N/A
Remote-AP bw reservation 2 N/A
Remote-AP bw reservation 3 N/A
Remote-AP Local Network Access Disabled
Bootstrap threshold 32
Double Encrypt Disabled
Dump Server N/A
Heartbeat DSCP 0
Maintenance Mode Disabled
Maximum Request Retries 10
Request Retry Interval 10 sec
Number of IPSEC retries 85
Secondary Master IP/FQDN N/A
AeroScout RTLS Server N/A
RTLS Server configuration N/A
RTLS Server Compatibility Mode Enabled
Slow Timer Recovery by rebooting itself Disabled
Telnet Enabled
Disable RAP Tftp Image Upgrade Disabled
Spanning Tree Disabled
AP multicast aggregation Disabled
AP ARP attack protection Disabled
AP multicast aggregation allowed VLANs none
Console enable Enabled
AP Console Protection Enabled
AP Console Password ********
Password for Backup ********
AP USB Power override Disabled
RF Band for Backup all
Operation for Backup off
BLE Endpoint URL N/A
BLE Auth Token N/A
BLE Operation Mode Disabled
Re: Newly converted IAPs to Campus APs registers the controller as Air Monitor APs.
What was the country code of the IAPs before conversion?
What model IAPs are these?
What version of controller code?
MVP
1) From the AP box the description I see is: ARuba IAP-315(RW).Not sure if this mean to signify "rest of the world".
Below is the network log for one of the AP which comes up as Airmonitor after its conversion from IAP to Campus AP
(WLC_002) #show log system 50 | include a8:bd:27:c1:81:2e
Apr 23 13:31:32 :311002: <WARN> |AP a8:bd:27:c1:81:2e@172.25.98.50 sapd| Rebooting: Rebooting after provisioning
Apr 23 13:33:59 :399803: <4012> <ERRS> |stm| An internal system error has occurred at file sapm_ap_mgmt.c function sapm_proc_hello_req line 12411 error Mismatched Regulatory Domain for AP(a8:bd:27:c1:81:2e), Ctrl CC(US) AP CC(RW). AP will come up in AM Mode .
2) These are IAP-315
3) The version of Controller code is : 6.5.0.2
IAPs that were ROW  but now converted to campus, cannot come up in an ap-group that is US...
MVP
As always, thanks Joseph for your prompt help.
Your responses and resolutions are faster than TAC :)
