Regular Contributor I
Nexus 7 ... rooted
Guys,
Anyone got any ideas why a nexus 7 (rooted) would be disconnecting to the WiFi?  We have a traditional controller/ CAP arrangement with amigopod captive portal.
Lots of retries on from the client with a low noise floor and low duty cycle.
I want to say, reset, and apply latest software update to the device, then check it works ok - then go back and root it etc. and after that you may have to make a call if you want a device that works or a rooted device.
Can't say I have ever hacked my andriod - anyone got any ideas?
Nik
Re: Nexus 7 ... rooted
Turn on user debugging and see why.
Yep already done that a few days ago - all seems fine, I can see the user moving between APs, authenticating successfully - some dissassociations though - the only one thing "wrong":
Deauth from sta: 10:bf:48:f1:07:6d: AP 10.24.11.123-d8:c7:c8:10:20:71-01-07-AP Reason 255
And an idle timeout
You got a link for reason code lookup for this deauth message?  rather annoyingly there is a gap in coverage on floors 2 and 3 of the building.
That meant that the Nexus 7 sent disassociation with no specified reason.
