Occasional Contributor I
No DHCP for Wireless station with Remote AP
I've a problem with Remote AP ...
When a client is connect on my SSID it doesn't can have an IP Adress... I try with a fix ip address on my station and it's work (I can ping on this network, navigate on internet...). I try directly connect to my switch and I receive an IP address.
I put an allow-all policies in user roles to be sure is not a firewall problem...
I don't know what is the problem ? Why only the DHCP service don't work ?
Thanks in advance for your help !
PS : Sorry for my bad english...
Re: No DHCP for Wireless station with Remote AP
What is providing dhcp?
Colin Joseph
Aruba Customer Engineering
Thanks for your response. I just find the solution.
In my AP group -> AP -> AP system -> Session ACL
My ACL don't allow the dhcp service. I change the policie and it's work.
Thanks for your help.
You didn't say that it was a bridged SSID...
Colin Joseph
