Contributor I
No Heatmaps for Cisco AP in Visual RF
Hi Everyone,
When I add Cisco APs to a floorplan in Visual RF, the heatmap, which usually displays an estimation of the signal propagation, does not seem to be working.
It works fine with Aruba APs.
I was wondering, is it normal?
Thank you!
Best regards,
