No Instant 4.3.2 on AP365 - Need help
Hi, I was trying to set up Aruba 365 outdoor access point and it doesent show the possibility to use instant even though its datasheet says it should.
It says its missing the image for it. Can someone tell me where I can get that image? Help very quickly would be very appriciated.
Re: No Instant 4.3.2 on AP365 - Need help
I am assuming you booted it up.
Is it broadcasting an SSID?
Contributor II
InstantOS 4.3.2 does not seem to be available yet nor ArubaOS 6.5.2
The latest available in the support site is 4.3.1.2 (InstantOS) from March 9th with no mention of IAP-365. For ArubaOS the latest is 6.5.1.3 from Feb. 16th.
I guess you will need the TAC or your Local SE to help you getting a Beta release!
Thank you, that is the case. It just comes as a suprise because looking quickly at the data sheet it looks like it should work. Sad that it says nowhere that this won't be available until later. I would suggest editing the data sheet so people will know about this because it has made a quite a mess.
