Hello, I have 2 access points AP 215 that the leds lights for 2.4 and 5Ghz stay off and theses AP are not working. They are provisionned and I see them on the controller but it have nothing write under 2.4 Ghz Channel and 5Ghz Channel (see screen shots). I tried factory_reset but same problem.
Is anyone could help me?
Here's the boot log:
APBoot 1.5.3.9 (build 43867)
Built: 2014-05-21 at 19:31:10
Model: AP-21x
CPU: P1010E, Version: 2.0, (0x80f90020)
Core: E500, Version: 5.2, (0x80212152)
Clock:
CPU0: 800 MHz
CCB: 400 MHz
DDR: 400 MHz (800 MT/s data rate) (Asynchronous)
LBC: unknown (LCRR[CLKDIV] = 0x00)
L1: D-cache 32KB enabled
I-cache 32KB enabled
I2C: ready
DRAM: Configuring DDR for 800 MT/s data rate
DDR: 256 MB (DDR3, 32-bit, CL=6, ECC off)
POST1: memory passed
Flash: 32 MB
L2: 256 KB enabled
Power: 802.3at POE
PCIe1: RC, link up, x1
dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
00 00 14e4 4360 00002 03 80000004 00000000 00000000 00000000
PCIe2: RC, link up, x1
00 00 14e4 4360 00002 03 a0000004 00000000 00000000 00000000
Net: eth0
Radio: bcm43460#0, bcm43460#1
Hit <Enter> to stop autoboot: 0
Checking image @ 0xee000000
Copying image from 0xee000000
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
[ 0.000000] Flash variant: variant0
[ 0.000000]
[ 0.000000] Aruba Networks
[ 0.000000] ArubaOS Version 6.5.4.1 (build 61494 / label #61494)
[ 0.000000] Built by p4build@rhodes on 2017-09-18 at 19:25:47 PDT (gcc version 4.5.1)
[ 0.000000]
[ 0.000000] P1010 RDB board from Freescale Semiconductor
[ 0.000000] Memory: 248728k/262144k available (10044k kernel code, 13416k reserved, 612k data, 376k bss, 6504k init)
[ 0.001512] Brought up 1 CPUs
[ 0.078132] PCI: Probing PCI hardware
[ 0.121232] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 0.184131] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
[ 0.246384] pci 0000:00:00.0: not setting up bridge for bus 0000:01
[ 0.320878] pci 0001:02:00.0: not setting up bridge for bus 0001:03
[ 4.939664] fsl-ifc ffe1e000.ifc: Freescale Integrated Flash Controller
[ 5.163444] ee000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank
[ 5.238483] Amd/Fujitsu Extended Query Table at 0x0040
[ 5.299981] number of CFI chips: 1
[ 5.354395] fsl-gianfar ethernet.2: enabled errata workarounds, flags: 0x4
[ 5.436789] gfar_probe: Renaming interface to bond0
[ 5.495601] /proc/gfar_bond0_stats created
[ 5.595597] Enabling watchdog on CPU 0
[ 5.642372] caam ffe30000.crypto: device ID = 0x0a14010000000000
[ 5.714313] caam ffe30000.crypto: job queues = 4
[ 5.769650] caam ffe30000.crypto: authenc-hmac-sha1-cbc-aes-caam
[ 5.841656] caam ffe30000.crypto: authenc-hmac-sha256-cbc-aes-caam
[ 5.915721] caam ffe30000.crypto: authenc-hmac-sha1-cbc-des3_ede-caam
[ 5.992936] caam ffe30000.crypto: authenc-hmac-sha256-cbc-des3_ede-caam
[ 6.072201] caam ffe30000.crypto: authenc-hmac-sha1-cbc-des-caam
[ 6.144182] caam ffe30000.crypto: authenc-hmac-sha256-cbc-des-caam
[ 6.223120] caam ffe30000.crypto: ccm-aes-caam
[ 6.362041]
[ 6.362046] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
[ 6.453807] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
[ 6.572695] Starting Kernel DES KAT ...Completed Kernel DES KAT
[ 6.644643] Starting Kernel AES KAT ...Completed Kernel AES KAT
[ 6.688439]
[ 6.734308] Starting Kernel HMAC SHA1 FIPS KAT ...Completed Kernel HMAC SHA1 FIPS KAT
[ 6.829589] Starting Kernel HMAC SHA256 FIPS KAT ...Completed Kernel HMAC SHA256 FIPS KAT
[ 6.951559] Starting Kernel HMAC SHA384 FIPS KAT ...Completed Kernel HMAC SHA384 FIPS KAT
[ 7.074481] Starting Kernel HMAC SHA512 FIPS KAT ...Completed Kernel HMAC SHA512 FIPS KAT
[ 7.197389] Starting Kernel AES-CBC FIPS KAT ...Completed Kernel AES-CBC FIPS KAT
[ 7.332220] Starting Kernel AES-CCM FIPS KAT ...Completed Kernel AES-CCM FIPS KAT
[ 7.432590] Starting Kernel 3DES-CBC FIPS KAT ...Completed Kernel 3DES-CBC FIPS KAT
AP-type has_ble_support: USB.
Domain Name: arubanetworks.com
No panic info available
ardmore: Start hotplug
Enabling ble_daemon via nanny
[ 17.923478] AP xml model 84, num_radios 2 (jiffies 8790)
[ 17.987073] apType 84 hw_opmode 0
[ 18.026679] radio 0: band 1 ant 0 max_ssid 16
[ 18.078783] radio 1: band 0 ant 0 max_ssid 16
[ 18.137398] init_asap_mod: installation:0
[ 18.563287] firewall cpu: core-0
ardmore: Copying BT modules to /tmp
Starting watchdog process...
Getting an IP address...
[ 22.846435] ADDRCONF(NETDEV_UP): bond0: link is not ready
[ 28.855478] PHY: bond0 (mdio@ffe24000:00) - Link is Up - 1000/Full
[ 28.929549] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
192.168.54.23 255.255.255.0 192.168.54.1
Running ADP...Done. Master is 10.54.10.71
[ 57.835128] wifi0: AP type AP-215, radio 0, max_bssids 16
[ 58.051532] aruba_usb_power_control:1136 en:1 status:0
[ 58.113098] aruba_enable_usb_block:556 Enabled USB
[ 58.170415] aruba_usb_power_control:1141 Enable USB power control for 214/215
[ 58.255858] tomatin_usb_power_control:975 enable the USB
[ 58.617129] wifi1: AP type AP-215, radio 1, max_bssids 16
03.00
ardmore: Insmod BT modules
[ 59.373088] usbcore: registered new interface driver usbfs
[ 59.616875] usbcore: registered new interface driver hub
[ 59.738098] usbcore: registered new device driver usb
[ 59.899067] usbcore: registered new interface driver usbserial
[ 60.189858] USB Serial support registered for generic
[ 60.250585] usbcore: registered new interface driver usbserial_generic
[ 60.328774] usbserial: USB Serial Driver core
[ 60.471003] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 60.549213] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
[ 60.628461] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
[ 60.774708] fsl-ehci fsl-ehci.0: irq 28, io base 0xffe22000
[ 60.848925] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
[ 60.915668] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 60.996960] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 61.083442] usb usb1: Product: Freescale On-Chip EHCI Host Controller
[ 61.160545] usb usb1: Manufacturer: Linux 2.6.35 ehci_hcd
[ 61.225149] usb usb1: SerialNumber: fsl-ehci.0
[ 61.336621] hub 1-0:1.0: USB hub found
[ 61.381486] hub 1-0:1.0: 1 port detected
[ 61.723568] usbcore: registered new interface driver cdc_acm
[ 61.791360] cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
shutting down watchdog process (nanny will restart it)...
<<<<< Welcome to the Access Point >>>>>
Thanks!
