No Traffic from Aruba WiFi AP?
Sometimes I use my phone connects to the Aruba WiFi AP and associate it successfully, but no any traffic from the AP? What happen? And I need to reconnect it then everything is ok?
Re: No Traffic from Aruba WiFi AP?
We probably will need more details about your issue:
See if any of your problems falls into the configuration realm by looking at the post here:  http://community.arubanetworks.com/t5/Technology-Blog/Removing-the-Bottleneck-in-Wireless/ba-p/77978
Many issues that look like that fall into either RF issues or broadcast management issues, especially if they are sporadic.
Colin Joseph
Aruba Customer Engineering
Dear Sir, it is my setting problems. Please forget it. Thank you.
Hi, my Aruba AP-215, I use my phone to connect it and access the Internet, but suddently Aruba AP-215 does not send any wireless packets to my phone, then I cannot access Internet. Any settings will make Aruba AP to do this? TCP SYN attach? or others?
Could you please let us know what the fix was? Thanks
