No WEB Access after upgrade to AirWave 8.2.4
Hi;
After upgrade my Airwave from version 8.2.3.1 to 8.2.4 I loss the web interface.
I still can access via SSH to the new AMPCLI, but I cannot access the web "Unable to connect".
Does it have any specific port without automatic redirect?
BR,
Tomaz.
Re: No WEB Access after upgrade to AirWave 8.2.4
I would request you to open a TAC case. It can be any of the below,
* Hard disk filled up
* issue with DB starting
Was the upgrade successfull? Did you notice anything on screen during upgrade.
From 8.2.4 since the CLI is locked, i would request you to involve TAC so that they can help you with the troubleshooting part.
Vishnu
If my post helped you, don't forget to give kudos ;)
Hi again;
I already opened a case through my partner (Plexus) the problem is I cannot upload the "support_connection.tar" file for remote support. I'm getting the error:
scp: support_connection.tar: Permission denied.
Error transferring file from 192.168.2.78: scp failed: child exited with code 1
I don't think it was a good option to lock completly the linux CLI. Now he are having these bunch of problems, special in a minor release 8.2.3.1 => 8.2.4.
Aruba should revert that decision asap.
Because of this I can't access Airwave since Sunday night.
BR,
Tomaz.
Tomaz,
How are we trying to transfer the file? Is it using a MAC/Unix or a Windows?
Could you share the support case number as well.
Vishnu
Unfortunatelly I don't have the case number as it was opened by the partner.
I already used 2 different windows programs:
Solarwinds and Bitvise.
But I don't know if the problem is on the PC or on Airwave server writing permission.
BR,
Tomaz.
I'm suffering from the same problem. This is becoming a clumsy update, there isn't any backdoor for support access?
Do you have another unix/linux or a MAC which you could use? Windows currently dont have an inbuilt scp and currently we support only scp for the file transfer.
Could you try using a MAC or a unix/linux box to scp the file?
Vishnu
Vishnu, it worked with Linux!
Anyway it's not acceptable you need a Linux (or Apple) machine to do that.
Please seriously consider to revert linux cli shell.
BR,
Tomaz.
Tomaz,
Good to know that it worked. Yes, i understand the pain here. Engineering is already working to get alternative options for this upload.
Vishnu
Frequent Contributor I
No specific port.  First upgrade i tried got the same problem.  No web access altough upgrade went fine.
Today i tried the upgrade again.  And now i had web access.  But... painfully slow...  After about 15 mins i started seeing on the console out of memory messages for httpd processes.  System has been running with 8 Gbyte of RAM for years without any issue...
I restored a snapshot.  Will skip this version...
