No clients can connect to AP
I'm having a odd problem i havnt run into before.
i moved an ap105 that was installed at another office (and previously worked properly) to my enviroment.  The AP showed up in the controller.  however no clients can connect to it.
any ideas?
It is set to machine authentication, MS, Protected EAP, WPA-Enterprise, AES.  (which is the same as other ap's, however obviously i'm overlooking something!) thanks!
Re: No clients can connect to AP
If you do a show ap active and show ap database do you see any flags ?
Do you have other working APs in that same segment/IP Space ?
Also do a show  ap bss-table ap-name <apname>
Thank you
Victor Fabian
Lead Mobility Architect
Aruba
Couple of follow up questions:
- Are the radio lights on?
- Did the AP change AP Groups when you moved it?
- When at the other location, was on this controller or another?
can you run:
show ap bss-table | include <NameofAP>
ACCX | ACDX | ACMX
