Contributor II
No internet conenction for Guest wireless
Hi All
Recently our modem router that is connected to our Aruba 7210 Controller failed.
This Mode router was used to grant internet access to ur guest wireless SSID's.
So we bought a new Modem router a Billion 7700Nr2 then configured it to connect to our ISP we also changed its IP address to the same we had our old one.
We also set it up as a dhcp.
We got it to connect to the internet and it seems that if we connect to it directly to it from a pc eveything is fine.
If we connect any device to it through our GUEST Wireless the clients connect and receive and IP from the dhcp of the modem and seem to connect ot the network fine.
Unfortunatley they do not get any interent access.
I cant work out if the aruba is blocking it or the modem is.
Does anyone have any ideas of what coudl be causing this?
Re: No internet conenction for Guest wireless
There are quite a few reasons why this would happen.  Who setup the 7210 on the guest network in the first place?  I would speak to that person, if possible.
Colin Joseph
Aruba Customer Engineering
Contributor II
Re: No internet connection for Guest wireless
I had spoken to the guy who set it up he was looking into oddly when I came in this morning it is now working.
It is very strange.
Best regards,
Anthony Duke
Network Administrator
SMR Automotive Australia Pty Limited
Sherriffs Rd ? Lonsdale 5160 ? Australia
My contact details:
Tel +61 (08) 8301-7726? Fax +61 (08) 8384-7799
SMR is a member of Samvardhana Motherson Group
Please don't print this email unless you really need to. This will preserve trees on our planet.
@SMR Users : We welcome your comments and suggestions, so please feel free to email your comments, suggestions & feedback to SMR Global IT head at gaurav.gulati@smr-automotive.com
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments. WARNING: Computer viruses can be transmitted via email. The recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus/trojan/worms/malicious code transmitted by this email. www.motherson.com
