Frequent Contributor I
No other user will able to connect to mac ssid ... How ????
Dear Sir,
I want to know only those clients will be able to connect to the mac ssid  whom mac addresses will be in the internal database . No other  users will connect to mac ssid ? when they try to connect , windows message will appera unable to connect .
What i have to do ?
Re: No other user will able to connect to Mac ssid ... How ????
  • mac-auth will allow u to create mac based on internal or external db.(but still un allowed users will be able to associate to the ssid - and to get  the initial role)
  • for what you are asking u should use 802.1x auth.(based on db of mac or user or cert or token)
