Not connected receipt printer Posiflex Aura - IP-address 0.0.0.0
I have Aruba 205 and receipt printer Aura 6800 (and Aura 9000) with support for Wi-Fi. When you try to connect the printer to a wireless network, the printer gets the address 0.0.0.0, instead 10.11.11.11. The printer can only be configured on static address, DHCP is not supported. How to diagnose the problem ?
With TP-Link and Zyxel all works well, the only problem with Aruba.
Output "Auth Trace Buffer":
station-up             *  00:0d:f0:9b:8c:df  a8:bd:27:00:ae:c1  -  -    wpa2 psk aes
wpa2-key1             <-  00:0d:f0:9b:8c:df  a8:bd:27:00:ae:c1  -  117
wpa2-key2             ->  00:0d:f0:9b:8c:df  a8:bd:27:00:ae:c1  -  117
wpa2-key3             <-  00:0d:f0:9b:8c:df  a8:bd:27:00:ae:c1  -  151
wpa2-key4             ->  00:0d:f0:9b:8c:df  a8:bd:27:00:ae:c1  -  95
