Contributor II
Not enough flash space
trying to upgrade 620 controller and i get the error "Not enough flash space".  cleaned everything out of filesystem that is not needed and rebooted still not enough space.
(controller_140) #dir
-rw-r--r--    1 root     root        22111 Mar 15 09:15 20130313-config
-rw-r--r--    1 root     root        22266 Mar 15 10:13 default.cfg
drwx------    2 root     root            0 Mar 15 09:36 tpm
(controller_140) #show memory
Memory (Kb): total: 387684, used: 294104, free: 93580
(controller_140) #show storage
Filesystem                Size      Used Available Use% Mounted on
/dev/mtdblock11         156.0M    118.7M     37.3M  76% /flash
none                    300.0M      2.2M    297.8M   1% /tmp
/dev/mtdblock9           50.0M     24.8M     25.3M  50% /mnt/img0
/dev/mtdblock10          50.0M     24.5M     25.5M  49% /mnt/img1
Re: Not enough flash space
type "tar crash" to see if there is a crash.tar file.  If there is, delete it, reboot and try again.
Contributor II
(controller_140) #tar crash
No crashes found on this machine.
Please open a support case.  TAC could see if there are any "hidden" files that can be removed...
I had the same problem and got back enough space after deleting all but two saved configs.
Contributor II
Upgraded the Controller using the CLI instead of GUI and it worked fine.
(controller_140) #copy tftp: 172.20.21.145 ArubaOS_6xx_6.1.3.7_37112 system: partition 1
Copying file:..........................
Saving file to flash:
(controller_140) #
(controller_140) #show image version
Partition               : 0:0 (/dev/mtdblock9)
Software Version        : ArubaOS 6.1.3.5 (Digitally Signed - Production Build)
Build number            : 35523
Label                   : 35523
Built on                : Fri Sep 28 07:46:05 PDT 2012
Partition               : 0:1 (/dev/mtdblock10) **Default boot**
Software Version        : ArubaOS 6.1.3.7 (Digitally Signed - Production Build)
Build number            : 37112
Label                   : 37112
Built on                : Fri Feb 8 18:08:20 PST 2013
(controller_140) #
(controller_140) #write memory
Saving Configuration...
Configuration Saved.
(controller_140) #
it worked with me just one time, when i tried again i got the free space error message!!!, any help please??!!!1
Try from the commandline or contact tac to see if there are any hidden files.
i did from CLI , no result, i am waiting reply from the TAC team
Contributor II
ran into the same problem trying to upgrade my controller to 6.3 only  this time the GUI and the CLI did not work.  I had to boot off the inactive partition (1) then upgrade partition 0 with the CLI and it worked.
