Number of Clients to AP data
Hi All,
I have 2 Aruba controllers (12103600) in the network and I was wondering how do I go about finding
the max number of Clients connected to each AP for the past 2 weeks. Not sure if this is possibl.e
Thank you in advance for your help.
-rbx10
Aruba
Re: Number of Clients to AP data
Without AirWave or some other offload of syslog files; you'll not be able to retrieve this historical information. However with AirWave you'd be able to this without problem.
AMFX | ACCX | ACDX | ACMX
