OS 6.4.3.5 and AirPlay
  • 1.  OS 6.4.3.5 and AirPlay
    MVP
    Posted Jan 28, 2016 08:12 AM
    We've recently upgraded from Aruba OS 6.4.2.5 to 6.4.3.5 and ever since then, we're no longer seeing all of our Apple TVs on the network when plugged in, not using wireless. We have 40+ Apple TVs at our Upper School campus but now, when plugged in to the network, I only see two. Is there a setting that's off?
  • 2.  RE: OS 6.4.3.5 and AirPlay
    Posted Jan 28, 2016 09:23 AM
    Were you using Airgroup? If yes, could you check,
    #show airgroup status
    #show airgroup servers
    #show airgroup global-credits
    Rajaguru Vincent
  • 3.  RE: OS 6.4.3.5 and AirPlay
    MVP
    Posted Jan 28, 2016 09:28 AM
    Nothing out of the ordinary when runningi these commands. What am I looking for?
  • 4.  RE: OS 6.4.3.5 and AirPlay
    MVP
    Posted Jan 28, 2016 09:29 AM
    (Aruba7210) #show airgroup global-credits
    Global Credits - Default
    Type              Value
    Query Packets     1350
    Response Packets  944
    Global Credits - Current
    Type              Value  packets drop - last half an hour  packets drop - last read  packets drop - total throttled
    Query Packets     1292   0                                 0                         0
    Response Packets  918    0                                 0                         0
  • 5.  RE: OS 6.4.3.5 and AirPlay
    MVP
  • 6.  RE: OS 6.4.3.5 and AirPlay
    MVP
    Posted Jan 28, 2016 09:30 AM
    (Aruba7210) # show airgroup status
    AirGroup Feature
    Status
    Enabled
    AirGroup- MDNS Feature
    Status
    Enabled
    AirGroup- DLNA Feature
    Status
    Enabled
    AirGroup Location Discovery
    Status
    Enabled
    AirGroup Active Wireless Discovery
    Status
    Enabled
    AirGroup Enforce Registration
    Status
    Disabled
    AirGroup IPV6 Support
    Status
    Disabled
    AirGroup Service Information
    Service     Status
    airplay     Enabled
    airprint    Enabled
    itunes      Enabled
    remotemgmt  Disabled
    sharing     Disabled
    chat        Disabled
    googlecast  Enabled
    DIAL        Enabled
    DLNA Media  Enabled
    DLNA Print  Enabled
    allowall    Disabled
    iphoto      Enabled
  • 7.  RE: OS 6.4.3.5 and AirPlay
    Posted Jan 28, 2016 09:59 AM
    Airgroup seems to be fine. So you a list of airgroup servers. Just to confirm...
    Do you find some Apple TVs missing from that list of airgroup servers?
    Are you not able to discover all the apple TVs on the airgroup servers list?
    Is your iPad/iPhone on the same vlan as the Apple TV or is it on a different VLAN?
    Rajaguru Vincent
  • 8.  RE: OS 6.4.3.5 and AirPlay
    MVP
    Posted Jan 28, 2016 10:15 AM
    When plugged in to the wired network, only Apple TVs that seem to be nearby show up. So right now, only 2 are showing up. When connected wirelessly, all Apple TVs on campus show up.
    Nathan Kuhl
    Information Technology
    Wyoming Seminary
    570-270-2241
    *** Please report all problems to the help desk: http://it.wyomingseminary.org***
  • 9.  RE: OS 6.4.3.5 and AirPlay
    Posted Jan 28, 2016 10:31 AM
    When you are wireless, all the Apple TVs show up, that is perfect.
    So when you are wired you can see only the Apple TVs that are nearby. It is possible that your Apple TVs are discovered by Bluetooth. Do you see that two Apple TVs if you turn off Bluetooth?
    If not, is your wired computer and your Apple TV on the same VLAN or different VLANs? You should be able to see the Apple TVs on the same VLAN.
    Rajaguru Vincent
  • 10.  RE: OS 6.4.3.5 and AirPlay
    MVP
    Posted Jan 29, 2016 10:27 AM
    You’re right, it is Bluetooth that’s making those couple of Apple TVs show up. But here’s the thing, prior to upgrading to 6.4.3.5, we were able to see all Apple TVs on the network when wired in, not just wireless. Did something change in the OS to cause this?
  • 11.  RE: OS 6.4.3.5 and AirPlay
    Posted Feb 01, 2016 01:34 PM
    In don't think there is any change in the OS.
    Does the wired computer have Layer 2 connectivity with the controller?
    Was the wired computer on the controller's user-table before upgrade? (# show user-table)
    Is the wired computer and the Apple TV on the same VLAN?
    Rajaguru Vincent
  • 12.  RE: OS 6.4.3.5 and AirPlay
    MVP
    Posted Jun 01, 2016 11:35 AM
    I just wanted to provide an update on this in case anyone else was having a similar problem. As of Aruba OS 6.4.3.0, wired users are no longer supported according to the release notes.
    "AirGroup Support for Wired Users Starting from ArubaOS 6.4.3.0, AirGroup does not support wired users."
  • 13.  RE: OS 6.4.3.5 and AirPlay
    Posted Jun 01, 2016 11:59 PM
    Hi.. Could you please share a snippet from release note for reference?
  • 14.  RE: OS 6.4.3.5 and AirPlay
    MVP
    Posted Jun 02, 2016 06:44 AM
    I thought I already did that in the previous post. But the snippet you're looking for can be found on page 5 of the ArubaOS 6.4.3.4 Release Notes:
