OS 6.4 and AP-61
Dear All;
I have an Aruba Controller 3600 with OS 6.3.1.2 and a lot of AP-61,AP-68 and IAP-93.
Now I purchased a new 15 IAP-103, but cannot join the controller.
I have to upgrade the controller to OS 6.4 but as I read at release notes it not supporeted AP-61.
What can I do ??
Re: OS 6.4 and AP-61
You can either use your new IAP-103 in Instant mode or replace your AP-61s.
Tim Cappalli | Aruba Security
You have to make a choice, unfortunately.
http://www.arubanetworks.com/support-services/end-of-life-products/
Thank you for All Replies ;
So OS 6.4 doesn't support AP-61,  Although the end of support date for AP-61 is 31-May-16. it's make a confusion.
end-of-support means TAC will no longer support the AP but because Aruba will offer different version of AOS, the AP-61 will remain supported on AOs 6.3 until the end of support date for the AP.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
