Occasional Contributor I
OS 8.1.0 Mobility Master sees less AP's than the Controller
Hi Community,
I am bit frustrated. At customer site we face following situation:.
Devices installed: Mobility Master with two 7220 controllers attached.
Problem: Within the mobility master dashboard and settings we see 265 connected AP's. None as not connected. In reality we should see 281. Loggin into the controller directly we see 265 campus AP's and 16 as down. After a reboot of the controllers and the MM the missing AP's show as connected clients are able to connect to them. After about 10 minutes the 16 are gone again. Has anyone got a hint ?
