OS Downgrade 3600 controller
I am adding a new local controller to my network, that has 6.1.0.x installed.
The master controller is running 5.0.2.0.
Can I downgrade the OS on the local to 5.0.2.0, or must I upgrade the master to 6.1.0.x?
Re: OS Downgrade 3600 controller
You can downgrade, just check the release notes for the supported downgrade path, if it is then you'll just need to upload the image to the backup partiition (i.e non-boot partition) then boot into this partition.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
