Frequent Contributor I
OS required for mobility master?
Just to check that virtual MM since mention as a virtual appliance, no OS will be required for it?
Frequent Contributor II
Re: OS required for mobility master?
No it wont. ArubaOS will come as part of VM.
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
