OSPF Route Limitation
How can I get information about the maximum possible ospf routes on every controller model?
From User Guide Version 6.1:
- Maximum OSPF routes is 1K.
From User Guide Version 6.3:
But what about the other controller models in version 6.3 and above ?
Thanks in advance,
Kokel
Re: OSPF Route Limitation
 From AOS 6.4 user guide
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Yeah, same difference.
My screenshot is from Alcatel-Lucent User Guide. Your from Aruba.
Does anybody know about the limitation for all other controller models (not the ones listed in the screenshot)?
Thanks!
