OSPF over L3 GRE
I'm testing in my lab, OSPF over L3 GRE tunnels using two 7005 controllers. I've got OSPF enabled on the tunnel interfaces, and redistributing a VLAN on each controller into OSPF. I don't see any neighbors nor do I see any new LSAs in the database. I believe my issues is that Hellos are not being sent over the L3 GRE tunnels. Any input on what I can do to correct this?
##############Controller 1
##############configuration
interface tunnel 2
        description "Tunnel Interface"
        tunnel mode gre ip
        ip address 10.99.99.1 255.255.255.252
        tunnel source 10.3.123.1
        tunnel destination 10.3.123.2
        tunnel keepalive
        trusted
        ip ospf area 0.0.0.0
router ospf
router ospf router-id 10.3.1.248
router ospf area 0.0.0.0
router ospf redistribute vlan 321
##############output
(Aruba-7005-1) (config) # show interface tunnel 2
Tunnel 2 is up line protocol is up
Description: Tunnel Interface
Internet address is 10.99.99.1 255.255.255.252
Source  10.3.123.1
Destination 10.3.123.2
Tunnel mtu is set to 1100
Tunnel is an IP GRE TUNNEL
Tunnel is Trusted
Inter Tunnel Flooding is enabled
OSPF is enabled on this interface
Tunnel keepalive is enabled
Keepalive type is Default
Tunnel keepalive interval is 10 seconds, retries 3
        Heartbeats sent 385, Heartbeats lost 83
        Tunnel is down 5 times
(Aruba-7005-1) (config) #show ip ospf neighbor
OSPF Neighbor Table
Neighbor ID  Pri  State  Address  Interface
(Aruba-7005-1) (config) #show ip ospf database
OSPF Database Table
Area ID   LSA Type  Link ID      Adv Router   Age   Seq#         Checksum
0.0.0.0   ROUTER    10.3.1.248   10.3.1.248   553   0x80000001   0x7c9b
(Aruba-7005-1) (config) #show ip ospf interface
Tunnel 2 is up, line protocol is up
Internet Address 10.99.99.1, Mask 255.255.255.252, Area 0.0.0.0
Router ID 10.3.1.248, Network Type POINT_TO_POINT, Cost: 1
Transmit Delay is 1 sec, State PTPST, Priority 1
Timer intervals configured, Hello 10, Dead 40, Retransmit 5
Neighbor Count is 0
Tx Stat: Hellos 156 DbDescr 0 LsReq 0 LsUpdate 0 LsAck 0 Pkts 156
Rx Stat: Hellos 0 DbDescr 0 LsReq 0 LsUpdate 0 LsAck 0 Pkts 0
         DisCd 0 BadVer 0 BadNet 0 BadArea 0 BadDstAdr 0 BadAuType 0
         BadAuth 0 BadNeigh 0 BadPckType 0 BadVirtLink 0
################Controller 2
################configuration
interface tunnel 2
        tunnel mode gre ip
        ip address 10.99.99.2 255.255.255.252
        tunnel source 10.3.123.2
        tunnel destination 10.3.123.1
        tunnel keepalive
        trusted
router ospf
router ospf router-id 10.3.1.249
router ospf redistribute vlan 322
################output
(Aruba-7005-2) (config) # show interface tunnel 2
Internet address is 10.99.99.2 255.255.255.252
Source  10.3.123.2
Destination 10.3.123.1
Tunnel is Trusted
        Heartbeats sent 392, Heartbeats lost 91
        Tunnel is down 7 times
(Aruba-7005-2) (config) #show ip ospf neighbor
OSPF Neighbor Table
(Aruba-7005-2) (config) #show ip ospf database
OSPF Database Table
0.0.0.0   ROUTER    10.3.1.249   10.3.1.249   69   0x80000001   0x759f
(Aruba-7005-2) (config) #show ip ospf interface
Internet Address 10.99.99.2, Mask 255.255.255.252, Area 0.0.0.0
Router ID 10.3.1.249, Network Type POINT_TO_POINT, Cost: 1
Neighbor Count is 0
Tx Stat: Hellos 0 DbDescr 0 LsReq 0 LsUpdate 0 LsAck 0 Pkts 0
****just noticed as I posted this that tunnel 2 on Controller 2 is not sending any hellos. Not sure why, but currently looking into it.
Re: OSPF over L3 GRE
Resolved my own issues.
Removed the master-redundancy configuration that I was testing. All is good now.
