Old AP integrate with 7010 controller
Hi All,
I have AP92, AP105 and AP115 managed by Aruba650 Controller. My client wish to upgrade the controller only. Can AP92, AP105 and AP115 managed by Aruba 7010 controller?
Re: Old AP integrate with 7010 controller
Hi Joy,
This has nothing to do with the controller hardware, but with the software, running on the controller. Check this website to see what is the last version, which supports those AP's
http://www.arubanetworks.com/support-services/end-of-life/#AccessPoints
When you have a "TBD" the AP is fully supported by all software versions. (Only those features will work, which can run on the AP hardware).
BR
Florian
visit our Youtube Channel:
https://www.youtube.com/channel/UCFJCnuXFGfEbwEzfcgU_ERQ/featured
Please visit my personal blog as well:
https://www.flomain.de
Occasional Contributor I
2017.9.13 updated. (AP92, AP105 & AP115 can work with ArubaOS 6.5 and ArubaOS 8.1)
Thank you for your information
